Old 07-29-2010, 12:55 PM   #1
Pads stuck - can't replace
I tried to replace the pads on my 986 today and encountered a problem - the pads wouldn't come out. I pushed the pistons back but there seemed to be other parts between the piston and the pad - the picture attached. That was the rear one. Even using the hammer and quite a bit of force didn't work. Is it normal ? What's the best way of removing them without damaging anything?
chris7676 is offline   Reply With Quote
Old 07-29-2010, 01:36 PM   #2
landrovered's Avatar
Those are anti rattle / anti vibration disks, they are likely stuck to the back of the pad. Take a putty knife and slide it between the back of the pad and the disk on the anti rattle device and it should seperate allowing you to remove the pads.
This is what they look like http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=996-352-086-00-M260&catalog_description=Rear%20Brake%20Pad%20Vibration %20Damper%20%2D%20Round%2C%20%33%30mm%2C%20%28%34% 20per%20car%2C%20sold%20individually%29%2C%20Boxst er%20S%20%28%32%30%30%30%2D%30%34%29%2C%20Each%20% 20
2001 Boxster S 3.6L, Zeintop
Old 07-29-2010, 01:51 PM   #3
That makes sense, thanks a lot, will try that
Old 07-30-2010, 02:04 AM   #4
Location: Seattle - It's not Hell, but you can see it from here!
if you can't separate them you'll have to remove the calipers.
dave
2001 Porsche Boxster S
1988 Porsche 928 S4
Dave928 is offline   Reply With Quote
