Old 03-09-2012, 07:53 AM   #21
97 Boxster's Avatar
Going to get after mine this weekend. Cant wait.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
Old 03-09-2012, 09:00 AM   #22
Schatten-Baum-Mechaniker
Easy and fast way to push the pistons back in using a simple 8inch pair of pliers.
I also open up the bleed valve so the fluid goes out instead of back into the system.
Then follow with a full bleed or flush.
Brake Pad Change - YouTube
detailed video
Porsche Boxster Brake Pad Replacement - YouTube
Tommy
2000 Boxster S
1973 914
tommy986 is offline   Reply With Quote
Old 03-09-2012, 09:08 AM   #23
Should be a 10mm hex head bolt. Torque to 63 ft-lbs on re-installation. Some people say that the caliper bolts are one-time use only and should be replaced each time they are removed.
Replacements seem to be Torx, size T55
Tommy
2000 Boxster S
1973 914
Old 03-09-2012, 05:25 PM   #24
97 Boxster's Avatar
Done and SOLID. What a great easy project. I did manage to break one of the "wear sensors" but I already had new ones on the way so that will be an easy hookup once they get here. This project can save you TONS of $$ from what the shops will charge you. Go to Suncoast or Pelican and purchase the new rotors and pads and get after it.
Phoenix, Arizona
