Old 05-25-2010, 10:32 AM   #1
Starter motor noise
Starter moter on my 2000 Boxter occasionally makes a dry bearing noise (whirr) as it disengages the engine. Are these oil bronze bushes or actual bearings? Does anyone have a spec. on these so I can heve new ones ready to fit at removal?
Thank you,
Doug Holley
doug@sterling is offline   Reply With Quote
Old 05-25-2010, 12:36 PM   #2
What you are hearing is the bendix not disengaging. Mine started to do it and as a shot in the dark I sprayed the starter bendix with "liquid wrench" to help the bendix become unstuck.
Has not done it agian in over a year.
Just a suggestion.
2002 S
Old 05-25-2010, 01:31 PM   #3
Thank you for your reply. Sounds simple enough next time I'm under the cover.
