Old 03-12-2010, 06:55 PM   #1
wipers out of sync
At first the left one didn't go all the way across to the left, though the right one did. I adjusted the left one to match the right, but now it moves much more slowly than the right one, and they collide. Anyone have any ideas on what might be going on?
- Jim
2000 Boxster S, Speed Yellow, Michelin AS/3 tires, 60,000 miles...
... and climbing.
OldBlevins is offline   Reply With Quote
Old 03-12-2010, 09:46 PM   #2
put up your hood and watch the mechanisms... see if you can spot an abnormality.
Old 03-13-2010, 05:41 AM   #3
07 Carrera S Cab
Boxtaboy's Avatar
Are you sure you fully tightened the nut at the base of the wiper arm? If it is loose, the arm movement will lag.
Old 03-13-2010, 10:38 AM   #4
Ah. There's a nut.... I didn't spot that. That sounds like the problem. I'll go look more closely. Thanks Boxtaboy!
- Jim
... and climbing.
Old 03-13-2010, 11:04 AM   #5
07 Carrera S Cab
Boxtaboy's Avatar
Yep, if you look at the base of the wiper arm, you can pluck off the plastic cap that covers it. Then, you'll see a nut there. Tighten it, and you should be good to go.
