Old 01-27-2010, 01:20 PM   #1
please help with torque setting of front suspension bar?
Hi does anyone know the torque setting
for the strut bar on the bottom left and
right of the front suspension ? It's the
bar that secures the suspension to the body.
Thanks in advance.
2002 S
jhandy is offline   Reply With Quote
Old 01-27-2010, 08:23 PM   #2
From section 40-4 of the Bentley manual, it says "control arms to crossmember, 120 NM (88 ft-lb)." Looking at the diagram, the fastener you're referring to is a horizontal bolt that goes through the lower control arm (and presumably a rubber bushing) with a crossmember flange on each side.
gschotland is offline   Reply With Quote
Old 01-27-2010, 08:41 PM   #3
thank you. i suppose it is time for me to buy the bently manual.
2002 S
Old 01-28-2010, 12:19 AM   #4
You can get it here for $62.97. That's just about the best price around.
http://www.renntech.org/forums/index.php?autocom=content&code=amazon
