Old 01-21-2010, 06:50 AM   #1
UPDATE - stiffenning of brake pedal
Dear enthusiats,
Just an update to the stiffenning of the brakes on my 99 boxster.
Turns out that water had entered into the master cylinder via the booster. Also found that water had initially collected in an area under the bonnet as the drains were clogged with dried leaves which eventually made its way into the booster and cylinder. Anyhow, after a thousand bucks later, it's all good (costs also included draining the brake fluid and replacing some pads).
le jolie rogue
lejolierogue is offline   Reply With Quote
Old 01-21-2010, 12:32 PM   #2
Good reminder for all of us to replace the fluid every coupla years! DOT 3 and 4 brake fluid is hydroscopic by nature.
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
Old 01-22-2010, 07:12 AM   #3
landrovered's Avatar
FYI: the word is hygroscopic, it seems like it would be "hydro" but alas it is not so.
landrovered is offline   Reply With Quote
