Old 12-09-2009, 07:11 PM   #1
Any suggestions on an Amplifier?
I am taking the next step up from my CDR 23 and getting the Pioneer Avic x710BT, but apparently I need an amplifier in order to install this. I know very little about car audio installation, so does anyone have any suggestions on what to buy? I am looking at the crutchfield website and there seems to be alot of options. I am planning on buying the ebay kit, but is there anything else I will need to install this nav system? I give it a whirl myself as it seems there is alot of information out there.
Greg
2003 Boxster S.... Schnell Short Throw Shifter, Xenons, 18" Carrera Lites, H & R Springs, 7mm/14mm spacers, Bose, Pioneer AVIC X710bt, Zeintop when it's cold
BeachBum is offline   Reply With Quote
Old 12-09-2009, 08:50 PM   #2
ChrisZang's Avatar
Actually it depends
So your big problem is that the 2003 has the optical (MOST) bus.
It will be hard to find an amp for that.
How many speakers do you have in your box 4 or 6?
If you have no rear speakers you could drive the two dash and two door speakers directly from the Pioneer unit (I have a 700 BT and drive 4 speakers with it and it works fine). However you will need to find the cables which lead to your speakers and connect them directly to your Pioneer.
I have the kit from treullionaire (I guess that's the eBay kit you're talking about) and
it's worth every penny.
Old 12-09-2009, 08:54 PM   #3
ChrisZang's Avatar
Ooops I just saw in your signature that you have the BOSE.
Here are the instructions you need:
http://www.renntech.org/forums/index.php?showtopic=20442&st=0&p=105137&
Old 12-10-2009, 04:37 AM   #4
mts
I used the Alpine PDX-5 with my MOST BUS car.
2004 550 SE #1081 of 1953 (sold)
1997 911 Targa (sold)
mts is offline   Reply With Quote
Old 12-10-2009, 04:46 AM   #5
I second the Alpine PDX amps. I have an Alipine PDX-4 150 in my 97. It is fantastic and very small!
PlayersExpress is offline   Reply With Quote
Old 12-10-2009, 09:49 AM   #6
thanks for the replies. Any other suggestions? I know this is a stupid question, but why do I need an amplifier to begin with? With the Bose system, do I need a 2 or 4 channel?
Greg
Old 12-10-2009, 10:19 AM   #7
mts
If you have the sub as well you'll need a 5 channel to have direct connections.
Old 12-10-2009, 08:25 PM   #8
I did a survey about a year ago of compact 5-channel amps that would fit in the approximate space of the stock amplifier. I came up with 3 good options:
Alpine PDX-5
Infiinty Kappa Five
Blaupunkt THA 555 PNP
All good choices I think. I ended up with the Blaupunkt for cost and availability reasons.
Demick
'04 Boxster S
demick is offline   Reply With Quote
Old 12-15-2009, 09:13 AM   #9
I know this sounds stupid, but I'm not sure if I have a subwoofer. I had the Bose upgrade when I bought it, but don't know about what is included. I have speakers on the doors that have the Bose logo and another Bose component in between the seats right below the wind guard. You can only see it if you turn around and look. Does this sound like a 5 channel set up? Also, would the pdx-5 amplifier with the avic x710BT be compatiblem with the Bose upgrade?
Greg
Old 12-15-2009, 04:10 PM   #10
Alpine PDX
Yes, good choice, they also have a baby-PDX now that will work simply with an alpine head unit...lower cost and probably a much simpler install
urban_legend is offline   Reply With Quote
Old 12-18-2009, 04:34 AM   #11
mts
You do have the sub, it's the one below the wind guard.
Old 12-19-2009, 12:11 AM   #12
Thanks for the replies. I have the pdx-5 ordered. I am hoping that I can connect this to the Bose system. Has anyone successfully done this before?
Greg
Old 12-19-2009, 04:36 AM   #13
mts
Yes, it's same amp and system I have.
