Old 11-19-2009, 09:10 AM   #1
Fast turn signal
In the last couple of days, my turn signal is clicking at about twice the rate it used to. What is the cause, and how can I get it back to normal?
I've got an 06 Boxster, still under warranty.
ehanauer is offline   Reply With Quote
Old 11-19-2009, 09:16 AM   #2
burned out bulb?
This can happen when a bulb is burnt out, or if the headlamp is not making a good connection with the headlamp receptacle.
I had this same problem, fast blinking signal, when replacing my front headlamps - I had to hold the headlamp housing in place from under the wheel well to make my new lights fully connect when pushing them into place.
I would check visually to verify all lights are working as expected. Let us know what you find.
pschaub is offline   Reply With Quote
Old 11-19-2009, 09:16 AM   #3
Porscheectomy
You have a bulb out. All cars do that.
Old 11-19-2009, 10:54 AM   #4
Some cars also use a flasher module that can go bad and cause the same effect.
Old 11-19-2009, 12:42 PM   #5
Blinker fluid is low.
Old 11-19-2009, 01:12 PM   #6
that just made me lol in the middle of class... professor looked at me funny...
stateofidleness is offline   Reply With Quote
Old 11-19-2009, 04:17 PM   #7
Whatda expect? The rear main blinker seals are known to be flawed.
Old 11-19-2009, 09:57 PM   #8
Wonder if Jake & Charles can develop a fix for this RMBS failure issue.
gschotland is offline   Reply With Quote
Old 11-20-2009, 08:31 AM   #9
pk2
Heh? obviously he has'nt changed the air in his tires recently. Oft overlooked.
PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
Old 11-20-2009, 01:48 PM   #10
Is Mobil an approved OEM Blinker Fluid supplier? If so is it really as good as proclaimed and worth the extra cost? TIA, Cheers, Regards.
Old 11-20-2009, 02:55 PM   #11
I thought it was the blinker intermediate shaft bearing going bad.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
