Old 06-02-2009, 11:34 AM   #1
Alignment
It seems like some of my alignment setting are not within the recommended specs. Should i worry?
The shop said this is the best they can do.
01 Boxster - Lapis Blue - Aerokit II Daily Driver.
98 Pontiac sunfire - Winter beater- TRADED IT IN FOR 200 DOLLARS
2010 Honda Civic Coupe - Gunmetal Grey - Lease ended and returned
2011 Mercedes Benz GLK350 - Gunmetal Grey
ramo80 is offline   Reply With Quote
Old 06-02-2009, 12:38 PM   #2
Getting an alignment on a Porsche is not something that all tire shops are capable of. You might try and get some info from other Porsche owners in your area as to where they get theirs done and if they are satisfied. Ed
cvhs18472 is offline   Reply With Quote
Old 06-02-2009, 12:56 PM   #3
See if you can find out who sets up Porsches for racing in your area
As they will know how to get "in spec" and what side of the spec does what for the car.
It really makes all the difference in the world who does the work. Racers know the tricks as they set up cars to save hundredths of a second per lap.
Old 06-02-2009, 01:19 PM   #4
ChrisZang's Avatar
Amen to that
Old 06-02-2009, 05:32 PM   #5
Those settings are ok, but in the right hands it could be so much better. The OCD in me would go crazy knowing that the left vs right side numbers are not not "matching"'.
The place I have been bringing it charges me $150, usually takes two or three trips on and off the rack and sometimes up to two hours. But they always get it to my satisfaction. Our local dealer has a guy that is brilliant with alignments and knows all the right moves, but it costs nearly twice as much.
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
Old 06-02-2009, 06:10 PM   #6
Speaking of OCD, did they do the alignment with you sitting in the car? It's never going to be accurate without the driver's weight in the seat...
Old 06-03-2009, 08:03 AM   #7
Unless there are some type-o's, those are some wacky settings.
Of most concern is the rear toe. Since the spec on front and rear toe is listed as positive numbers, I have to assume that a positive number refers to toe-in on this sheet. The front is fine, but the rear is not in spec, and appears that they have given you toe-out on the rear. While toe-out might be desirable to some autocrossers, this can make the car unstable at speed. I would demand that they fix this as there is no reason they cannot bring this to within spec.
Everything else is OK, but not ideal. As Mike pointed out, the tech in this case was only trying to get a number that was within 'spec' (and he failed to even do that in some cases). A good alignment will target a certain number for each setting rather than anywhere in the spec range. A good alignment won't have positive camber on the left front and negative camber on the right front - despite both being within 'spec'. This kind of alignment is fine for your minivan, but not appropriate for a performance car.
Demick
'04 Boxster S
demick is offline   Reply With Quote
Old 06-03-2009, 10:54 AM   #8
Brutal!!! I paid that guy 200 dollars and he said he know what he was doing!!!! He specializes in german cars. Not porsches i guess. I don't race my car so its just for street use. Will I be seeing premature tire ware??? I just bought 4 new tires and i don't want to waste them! Should i just drop another 250 and get Porsche to do it.
Thanks for all your help!
Old 06-03-2009, 10:55 AM   #9
and No i was NOT sitting in the car. I am very pissed off right now
Old 06-03-2009, 11:22 AM   #10
Umm no. I suggest you take your car to a reputable shop like Mantis Racing in Oakville to have it done. They're heavily into racing so I presume have nice alignment machine at the shop.
I paid $150 to do mine at the east end of GTA (with Hunter alignment machine) that deals with a lot of P & F cars.
Old 06-04-2009, 11:45 AM   #11
Hey I am in Milton too! Don't worry about not being in the car. It was a joke. Mantis is good but by far the best shop in the GTA is EU Autowerks. Pm me and I will hook you up.
__________________________________________________
Marc
2001 Boxster S
Mostly stock... except for all the things that are changed.
www.dexterautosport.com
http://www.pbase.com/image/89146172.jpg
mdex is offline   Reply With Quote
