Old 05-23-2009, 10:49 AM   #1
Ignition switch chiming
The last couple of times after I shut the car off and pulled the key out of the ignition, it would start to chime like the key is left in the ignition, or the headlights were left on. I am able to stop the chiming by pressing on the ignition switch key opening. What can I do to correct this problem? MY 99. Thanks Jim
jrblackbox is offline   Reply With Quote
Old 05-23-2009, 12:51 PM   #2
Jim, on these cars all kinds of weird things happen when the ignition switch is going bad. And they do go bad. A replacement is cheap enough...about $10 from ********************************Az. I have never replaced one but I understand that it is easy enough. A search will probably turn up directions for changing it out. Good luck.
Norm
Norminhouston is offline   Reply With Quote
Old 05-23-2009, 01:49 PM   #3
jrblackbox,
Try this link...
http://industryfigure.com/berkeley/Porsche/ignitionswitch.htm
Like Norminhouston mentioned, ************************************************************ has it for $8.78.
Taking the seat out helps a lot.
derb is offline   Reply With Quote
Old 05-24-2009, 06:29 AM   #4
ignition switch
Mike, Thanks for the link, that's what I needed, next week I will pick up that switch and attempt it. Jim
Old 05-24-2009, 07:04 AM   #5
07 Carrera S Cab
Boxtaboy's Avatar
Jim, while it does give you more access to the switch when you remove the seat, it really is not necessary. Take a look at Pedrosgarage instructions I posted below.
When you remove your seat, there is always the slight chance that you either strip a bolt, or forget to take the ignition key out, and your airbag light ends up going on, so try it without taking the seat out first. Pedro has replaced a bunch of them and does not recommend removing the seat.
Instructions found here:
http://pedrosgarage.com/Site%203/Replace%20Ignition%20Switch%20%20%20.html
Old 05-24-2009, 04:24 PM   #6
Rich, Thanks. Yeah, I was going to try to do it without taking the seat out, I figured that I would be able to contort myself and get under the dash. I will use a small stool to make manuvering around a little easier. Jim
