Old 02-22-2009, 02:39 PM   #1
1997 boxster fusebox/relay layout
Does anyone know where to get a fusebox/relay layout for a 1997 boxster?
Basically a drawing telling what fuse/relay does what...Thanks
suburban99 is offline   Reply With Quote
Old 02-22-2009, 03:32 PM   #2
There Is No Substitute.
rick3000's Avatar
Here is the relay panel:
http://theschillings.com/boxrelay.htm
I don't recall ever seeing the fuse panel on the net, but some searching may find it.
The Bentley manual has all of the fuse and relay layouts and wiring, it is well worth $70 to get.
Old 02-22-2009, 04:04 PM   #3
Thanks rick3000
I have ordered the Bentley service manual. Apparently it is the best...hopefully someone has the fuse panel layout.
Old 02-24-2009, 05:32 AM   #4
also..
Behind the fuse door (at least in my 02 S) there is a folded up paper wiring diagrams. You could check with a dealer for availibilty.
A Bentley manual is the way to go as it covers so many aspects. It's well worth the cost even if you don't do your own work.
-- 02 Boxster S
-- Black/Black
-- Sideskirts/PSE
Sputter is offline   Reply With Quote
