Old 02-09-2009, 12:50 PM   #1
Can the Porsche Plugin charger works for Mercedes
I have a c320 and want to know if I can use the Porsche Plugin charger click here for the c320. Does anyone has experience with that?
Thanks.
2006 Seal Grey Boxster
Sport Seats
19" Carrera S Wheels
n4ally2 is offline   Reply With Quote
Old 02-09-2009, 01:15 PM   #2
The Porsche branded charger is not
a charger but a maintainer. It will not charge a run down battery. It will maintain one at or near full charge.
You need 3 things...a cigarette lighter socket In the C320 that fits the Porsche charger, a lighter socket that is powered directly by the battery and isn't switched off when the ignition is turned off and a 12v system. We know you have the last, perhaps you can tell the first 2.
Old 02-18-2009, 10:48 AM   #3
Yes, I have all the parts. I just want to make sure that this maintainer can be use on my MB. You think it is okay?
Sport Seats
Old 02-18-2009, 11:52 AM   #4
Yes - you'll be fine w/ no problems. Maintainers are for the battery and batteries are, for the most part, the same 'technology'. Porsche doesn't make the maintainer itself either. They usually just re-brand others. For instance, the Porsche Charge-o-mat II is just a re-branded c-Tek 3300.
c-Tek
You can either plug it into the cig lighter (provided your cig lighter isn't switched off w/ ignition as Mike stated) or you can connect directly to the battery. Either way, what you have will work w/o any problems.
