02-03-2009, 09:03 AM
#1
Will a Boxster S Muffler fit on a Standard Boxster?
I've been having rattling issues with my exhaust on my 2002 986 2.7 for a while now. I recently installed the Maxspeed Sport Headers with the high flow cats and secondary bypass pipes. But the rattle is still there so it's got to be in the muffler. I don't want my car to be too loud and I like the sound of it now (aside from the rattle) So I want to stick with OEM exhaust.
I just bought a muffler in perfect condition with only 7K miles on it from a 2002 Boxster S and got it for $20 +shipping. But now that I'm looking at the pictures of it compared to my muffler it appears that the mounting brackets are different between the standard and the S. Why is that?
Actually, I'm not sure if it differs or not at this point until I take my own muffler off. I've looked on Ebay at varying years, S and Base and not sure if the mounting style is different based on year or based on S vs Base. anyone know the detail on the mounting variations on the muffler? Has anyone here ever converted one over to fit? Is it even possible? Or am I SOL and will have to resell this thing on Ebay?
Thanks,
Tim
TimAustinW
http://i226.photobucket.com/albums/d...ignature-1.jpg
02 Seal Grey, NHP Headers w/ Highflow Cats/2ndary Bypass Pipes, smoked side markers/3rd brake light, exterior match interior trim, 986 Lloyds Mats, 986 deck lid emblem, arctic silver intake grills, ipod link, painted calipers, Glass Window Robbins Top with defroster kit, Bose Sound System, Leather lower door panels, Console Lid w embroidered crest; Stainless door sills; Painted Bumperettes; Custom Hood Crest
02-03-2009, 09:39 AM
#2
If I'm not mistaken, it should bolt right on. Porsche changed the way the standard muffler mounted for MY 2000. Earlier 2.5's needed an adapter, but your 2.7 should be good to go.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
02-03-2009, 10:02 AM
#3
Oh man I hope so. The muffler I just bought is from an S but it's from a 2002, same as mine. That would be sweet if it was a swap.
Pelican Parts is what is having me doubt. When I went there for new fasteners and clamps I noticed they have two separate exhaust pages for the S and Base. That's where I noticed the difference.
Boxster S Exhaust Parts Diagram
Base Boxster Exhaust Parts Diagram
But then again the diagram they have for the non S is showing a 2.5 headers and midpipes with cats setup. So it may be the same with the muffler in the diagram.
I guess I will find out when it arrives.
TimAustinW
02-03-2009, 11:16 AM
#4
07 Carrera S Cab
An 02 S muffler will fit your 02 base with no issues. The muffer is exactly the same as yours except for the dual tip welded on the end of it.
I used to have a rattle at idle on my muffler too, and at first thought that the muffler had a loose piece inside it, but later traced it to a loose clamp that connects a U-pipe from the cat to the muffler. If I pulled on the u-pipe, I could tell that it was loose and would move. After fixing that, no more rattle.
02-04-2009, 10:22 AM
#5
Thanks Boxtsaboy,
I'll check the clamp. I was thinking it was the baffling inside the muffler because the exhaust tone alternates from sounding very nasally or froggy to sounding deep and smooth like a porsche should sound. I'm envisioning a piece of metal inside that's shifting changing the flow of air through the muffler. But even if it's just the clamp I'll still swap the muffler. It has about 80K miles fewer on it and it has the dual tips. And since I've already swapped out my headers and secondary cats with performance headers and secondary bypass pipes the muffler can be the only culprit left.
TimAustinW
02-04-2009, 12:40 PM
#6
Hey Tim, yeah like said above, give the clamps a shot to get rid of the rattle...
I'm curious to your impressions of changing to the performance headers and bypass pipes. Would you please elaborate on your driving impressions with these new parts? Did you feel any power gains, or differences in how it performs?
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
02-06-2009, 09:34 AM
#7
I did notice a difference. It feels like I've gained some HP. Not a huge amount. Maybe 10-15 if I had to guess. The biggest difference is in sound. It's definitely louder but since I kept the stock muffler it's not so loud as to upset the neighbors. It sounds great (when my muffler isn't acting up) around 3K rpms in 2nd and 3rd. So far I am very satisfied with the NHP headers and pipes.
My new muffler is out for delivery!!!
TimAustinW
02-08-2009, 01:16 PM
#8
How about a 2000 S exhaust system... Will it fit on a 2002 base boxster?
Will I require a mounting kit or any extra hardware?
02-09-2009, 08:41 AM
#9
As mentioned previously, Porsche changed the mounting system on the base car in 2000 to be the same as the S...2.7 and 3.2 are interchangable.
JGM
2002 Boxster S
04-27-2021, 06:48 PM
#10
did you fit the boxster s exhaust to your base?
I’m trying to get a 2004 Boxster S sport exhaust for my 2004 Boxster base model, but read that they did not fit. Were you successful? Send an email, please, to brucehaupert22@gmail.com
