Old 10-10-2008, 02:20 PM   #1
Strange noise when I shift from 1st to 2nd...
Recently I have noticed a loud thumping noise coming from the center of the car underneath, right after I shift and put the car into 2nd gear. It’s not my clutch, because it’s brand new, only a few months old. And it only seems to do it when the car is first started. After driving around for a while and I reach normal engine temperature, the noise stops. It’s only when I go from 1st to 2nd. And only when the car is cold. Is this some sort of transmission problem? It sounds like a loud thump. I can baby it if I release the clutch really incredibly slow it doesn’t do it at all. Motor Mounts perhaps? Or is this normal until the car warms up and trans fluid is circulating? My car has 71k on it. I don’t ever remember it doing this before. But I could have been shifting aggressively. Anyone have any ideas?
porsche986spyder is offline   Reply With Quote
Old 10-25-2009, 08:24 PM   #2
you know what, mine does the same when cold...almost as if the gears are grinding. is that what you're experiencing also ?
Joee - Toronto, Canada
2000 Arctic Silver Boxster w/997 GT-3 bumper and skirts
joee76 is offline   Reply With Quote
Old 10-26-2009, 08:28 AM   #3
It sounds like a torn front engine mount.
Pinarelloman is offline   Reply With Quote
Old 10-26-2009, 08:40 AM   #4
My engine thunked around a bit between gear shifts when I first picked it up.
After the mount was changed, the thunking went away.
If you know what engine motions you're looking for, you can remove the engine bay top cover, and check the mount as you drive the car up and down your street.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
Old 10-26-2009, 11:35 AM   #5
front motor mount. buy the upgraded caymen replacement, there is a DIY somewhere on the net for this. You need a floor jack to support the motor and then its easy as pie.
2002 S
jhandy is offline   Reply With Quote
Old 10-26-2009, 12:12 PM   #6
I have the same problem, its like a loud thunk and i can downshift into 2nd unless i go up to first. It seems the higher rpm i shift the less the thunk...I just had a 3.6 put in with new motor mounts so i wonder if thats the issue...
BoxsterLewis is offline   Reply With Quote
