Old 05-31-2008, 03:38 PM   #1
seat question
Was wondering if it is possible to switch my drivers and pass. seatbacks to balance out the wear? I have a '99 with power heated leather seats. Driver seatback is very worn on side from sliding in and out.
Thanks for any info or tips.
later
dave
rockbox is offline   Reply With Quote
Old 05-31-2008, 05:33 PM   #2
Franco's Avatar
Hi, I do not know about switching the seats but you can remove the leather and switch it around.
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
Franco is offline   Reply With Quote
Old 05-31-2008, 07:01 PM   #3
Jaxonalden's Avatar
I don't think swapping out the seat cover will work. The seats have levers on the outside that tilt them forward. Swapping that kind seat cover won't work and if you just swapped the backs you will have the same problem to include the latch for that seat. The bottom seat won't match-up with the latching mechanism.
Wish I knew what to say except to buy a new drivers side seat cover or find a good used one.
Old 05-31-2008, 11:26 PM   #4
I just double checked and my seats have release levers on both sides, would that make a difference ?
later
dave
Old 06-01-2008, 06:04 AM   #5
Jaxonalden's Avatar
Well then...I guess your good to go.
Old 06-01-2008, 06:23 AM   #6
There Is No Substitute.
rick3000's Avatar
I don't think you'll have a problem switching just the leather from the seat backs. But your probably won't be able to switch the lower part of the seat with the controls.
Old 06-01-2008, 08:14 AM   #7
Franco's Avatar
later
dave
Hi, I had already checked 4 U, now can you switch the leather and let me know how it goes , I might just do the same.
2014 Honda CRV
Old 06-01-2008, 08:18 AM   #8
The seats have levers on the both sides to flip forward, but the controls are on the outside of both seats, and depending upon whether you have full power seats, the wiring is different. I don't see why you couldn't swap the leather, but the full seat will be an issue- unless I'm missing something?
Patrick
Old 06-01-2008, 01:21 PM   #9
Patrick
I would just switch the seatbacks, the bottoms are in good shape and still comfy even after 84k mls, unless just changing the leather is easier?
later
dave
Old 07-16-2015, 01:42 PM   #10
Anybody do this? Removing just the backs of seats with double latch release and switching worn out driver's side with new passenger side. They (the backs only) appear to be of identical symetrical construction. Many of the above posts missed the actual question of switching just the backs with leather intact and not the entire seat.
luckyed7711 is online now   Reply With Quote
Old 07-17-2015, 06:08 PM   #11
KevinH1990's Avatar
I switched the leather on mine. So I have not actually swapped the backs myself.
However, others claim that it is possible - see the second post in this thread: http://986forum.com/forums/general-discussions/51674-seatbacks-interchangeable-passenger-driver.html
The thread includes links to instructions for disassembling seats. Its not that hard, so if it doesn't work it will only be an hour or two lost.
http://986forum.com/forums/diy-project-guides/50255-boxster-seat-disassembly-procedure-part-1-2-a.html
Good luck.
Old 07-18-2015, 09:56 AM   #12
Thanks Kevin for pointing me toward the further info. I may give it a shot. If I get around to trying it I will post results.
