08-01-2013, 09:34 AM
#21
If you had a flashing check engine light it would not go off on its own, so I would relax a bit. It is probably the AOS (air/oil separator) and there are a number of threads on the subject that you should search and read. You can have a check done of the crankcase vacuum to confirm, but what you describe (as well as regular white smoke on start-up) are common signs. I would not wait until it completely expires as it will make a mess of the throttle body and the MAF sensor.
Brad
08-01-2013, 10:39 AM
#22
Brad
Thanks! I'm on Pelican Parts - have the boot, AOS, both tubes, clamp, and o-rings...that should do the trick right? I'm trying to get it in by tomorrow.
Cheers,
08-01-2013, 04:01 PM
#23
Cheers,
The engine starts dying when I open the oil fill cap and is pulling a vaccuum, so I'm guessing (and from some brief mention of it on another thread) that it is indeed the problem. I figured if it wasn't the AOS, I'd have a new one so one less thing to worry about on the to-do list...
08-02-2013, 05:48 AM
#24
Yes, the vacuum is another sure fire sign. And yes, those are the parts you should need. That and a pair of gloves!!!!! Keep us posted.
Brad
08-02-2013, 09:39 AM
#25
Brad
I went ahead and got plugs, plug-orings, plug boots, air, oil filter, and other misc stuff. While I'm there - might as well start on some of the other maintenance. Thanks!
Cheers,
R
08-02-2013, 10:25 AM
#26
Mình chua hi?u cái nÃ****y cho l?m
Tai game mien phi cho dien: http:// trangtaigame.mobi
09-01-2024, 11:56 AM
#27
Hello I am having the same issue with my Boxster 1999.It’s blowing thick clouds of white smoke but it’s intermittently.i know the shop I took it to over filled the oil and since then Iv drained it to where it should be but I can get a mile down the road no issues but then when give it a little throttle to say 45 50 miles per hour it starts with the white smoke.any help or suggestions would be greatly appreciated.
