Old 04-11-2008, 06:18 PM   #1
you have the new cap. The old style ended with'00. Based on the coolant, you may need to replace the bleeder valve o-rings located under the cover plate. If you take off the coolant and oil caps, you can remove the cover plate to see if there is any coolant around the bleeder valve.
There are 2 o-rings that can wear that seal the bleeder valve cap.
Worst case, you may have a cracked coolant tank. Lift the carpet and remove to foam to see if there is any coolant present. If the level is low in the tank, this may be your problem.
ancster is offline   Reply With Quote
Old 04-11-2008, 07:54 PM   #2
Best guess is the cap is gone bad.
I can see coolant in the picture and it should be bone dry. Also you might see coolant on the ground just ahead of the rear wheel. I bet you have moisture on the trunk lid above the tank as well. Check the peek window on the tank to check the level.
NEVER use regular coolant. Use the Porsche brand mixed with distilled water 50/50.
-- 02 Boxster S
-- Black/Black
-- Sideskirts/PSE
Sputter is offline   Reply With Quote
Old 04-11-2008, 08:06 PM   #3
Whats the difference between regular coolant and the porsche stuff? The carpet around the tank was dry, so there isn't like a massive leak.
There was moisture on the trunk lid above the cap. Can the new style cap that I have still go bad? Wasn't this the point of the "new style" cap was to prevent the problems the "old style" had?
Lamborghini Murcielago (current)
Supercharged Viper SRT-10 800 HP Special Edition #49 of #50 (current)
Ferrari 360 Spider
Lamborghini Diablo VT Roadster
911 Cab
Boxster S (current)
08 Hummer H2 (current)
BMW Z3 (current)
Limos in Ohio and PA - First Class Limo Columbus Limos
http://pteam.net/avatar3.jpg
my car collection *Porschephiles agree, Desnorkify your Porsche!*
pteam is offline   Reply With Quote
Old 04-11-2008, 08:30 PM   #4
If you mix the two you will likely end up with jello in your system. There are other brands you can use but usually only after a total flush. I don't recall offhand the chemical difference. Check Renntech.org.
It can. I know I had to swap .01 cap for another .01 once.
-- 02 Boxster S
-- Black/Black
-- Sideskirts/PSE
Old 04-11-2008, 08:36 PM   #5
You don't mention what the lvl was in the tank. I virtually check my coolant and oil lvls daily. I'm anal that way.
-- 02 Boxster S
-- Black/Black
-- Sideskirts/PSE
Old 04-11-2008, 09:31 PM   #6
Send a message via AIM to blinkwatt
The newest caps now end in .02
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 04-12-2008, 05:35 AM   #7
husker boxster's Avatar
The antifreeze isn't a matter of having to use Porsche brand (although some will insist you do), it's a matter of using a phosphate-free antifreeze. Your garden variety brands contain phosphates and if you add it to a system that requires phosphate-free antifreeze you will generate a nice gell in your system that will halt any flow. Many European cars, not just Porsches, require phosphate-free anitfreeze.
Also be aware there are early and late types of phosphate-free antifreeze for European cars. Zerez makes a brand in a gold bottle (I think it's called M30) that is designed for Porsches up to 1995. Obviously that won't work with your Box.
Haveline Extended Life (Dex-Cool) antifreeze will do the job.
1989 928 S4 5 spd - black
