Old 04-01-2008, 02:58 PM   #1
Heated seats - retrofit possible?
Anyone know if it is possible to intall the heating elements without replacing the entire seats? I hate having those two cute button locations without heated seats to go along with them!
Seems to me, and I've never seen the underside of a heated seat mind you, that there should just be a heating element that goes under the seat, and wires back to a high current relay, two I guess to acheive the Porsche two-step heating sequence. But I don't find anything about this in the archives. Might be a wrecker item?
Kevfra is offline   Reply With Quote
Old 04-01-2008, 06:25 PM   #2
it's probably easiest to swap out the seats & add the relay, harness & switches. i do have instructions on how to do a retrofit to non-heated seats (it IS possible). i'll try to dig them up & post them.
insite
'99 Boxster
3.4L Conversion
Old 04-01-2008, 07:05 PM   #3
You can swap out the seat foam, and run all the wiring, but it will be easiest and most cost effective to just swap seats. I have done this myself, its actually not that difficult.
Patrick
Old 04-05-2008, 10:44 AM   #4
Can you post them or email me them? I might have to do this shortly.
Thanks,
Robert
gl-g100rcd@sbcglobal.net
Old 04-05-2008, 01:30 PM   #5
There Is No Substitute.
rick3000's Avatar
Here are the instructions for the OEM way:
http://www.dennisvogel.com/heatedseats/index.html
You might be better off to look into an aftermarket kit, then wire it with the OEM switches, to the switched 12V power under the center console. It may not be OEM, but you could probably do it for less that $300 or so, vs., $2000.
Old 04-07-2008, 07:30 AM   #6
ah, you beat me to it. i thought i had that link saved, but apparently not.....
insite
'99 Boxster
3.4L Conversion
Old 04-07-2008, 06:38 PM   #7
dont swap out the seats and spend thousands! thats crazy, I've used aftermarket seats on my box and my viper from http://www.heaterseats.com/ they work great
Lamborghini Murcielago (current)
Supercharged Viper SRT-10 800 HP Special Edition #49 of #50 (current)
Ferrari 360 Spider
Lamborghini Diablo VT Roadster
911 Cab
Boxster S (current)
08 Hummer H2 (current)
BMW Z3 (current)
Limos in Ohio and PA - First Class Limo Columbus Limos
http://pteam.net/avatar3.jpg
my car collection *Porschephiles agree, Desnorkify your Porsche!*
pteam is offline   Reply With Quote
Old 04-07-2008, 07:13 PM   #8
yeah I agree get after market heat elements. Pull the seats have them installed by a upholster. Then go find a good 12v installer and have them wire up to OEM switch. That would have to be the best looking way and the cheapest. Or just use their switch or search at radio shack for ones you like. I used to do this at a shop. Just find the sunroof installer type people and they will do it all for around $350-$500.
00' Porsche Boxster S
99' Subi 2.5 rs
00' Audi A4/S4
(www.myspace.com/tcechelon)
mn box s is offline   Reply With Quote
