Old 01-06-2008, 03:16 AM   #21
Here's the verdict. 1% increase in Horsepower every 10 degree colder. :dance: You do the math. It makes quite a difference. Comparing 90-100 degree summer vs. the 10-20 degree winter.
http://blogs.sportcompactcarweb.com/1004173/editorials/cold-weather-horsepower/index.html
http://image.sportcompactcarweb.com/f/editorials/cold-weather-horsepower/1032071+w700+cr1+re0+ar1/dyno-pull.jpg
ichiro75 is offline   Reply With Quote
Old 01-07-2008, 07:04 AM   #22
Porscheectomy
It's not quite that much, but it's a decent rule of thumb.
Old 01-07-2008, 10:24 AM   #23
Assuming you are talking about Fahrenheit degrees, and only density effects, it's actually bigger than 1%/10F. The math is quite trivial, just turn your temperatures into absolute (Rankine scale) and divide them (the ideal gas law, more specifically Guy-Lussac's law, only have linear terms making things easy).
E.g.,
t0 = 70F = 529R
t1 = 60F = 519R
density change = t0/t1 = 529/519 = 1.019
In other words, 1.9% increase in density.
(Hey, admins, fix the [ code ] block in your php...)
efahl is offline   Reply With Quote
Old 01-07-2008, 01:35 PM   #24
Porscheectomy
E.g.,
t0 = 70F = 529R
t1 = 60F = 519R
The % will be different depending on the actual temperature (40 vs 50 vs 60 ect) but that's just density, not power.
