Old 12-06-2007, 05:38 AM   #1
Question How can I tell if my Cats are getting cloged?
Is there a time frame when they should be changed out? My 99 has 58k on it and in the Spring it is getting new headers/exhaust. I was planning on keeping the original Cats but when it (barely) started this morning after its cold nap I watched the exhaust and it just kinda seeps out at idle. Is that normal for this car? I am used to seeing a little more of a steady flow from cars.
Thanks,
Chris
Dragonwind is offline   Reply With Quote
Old 12-06-2007, 06:38 AM   #2
Well if you look inside it with a flash light once the exhaust is apart, the honey comb inside shouldnt have any blockage. A way i've seen my father test it on other cars is to drill a hole in the exhaust pipe before the cat and if the flow improves alot, then its likely the cat is clogged.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 12-06-2007, 07:53 AM   #3
Thanks. Seeing as both sides are identical it is probablly normal. Never the less I am probablly going to put in the Maxflow muffler w/ cats so it will be a moot point. I think I may go with Deluboz's headers though.
Chris
Old 12-06-2007, 12:07 PM   #4
Many exhaust shops will do this (drill a hole in front of the cats, measure with a pressure sensor to see if there is too much back pressure) and then weld the hole. It cost me $20 to do mine on a Volvo.
saaber is offline   Reply With Quote
