Old 12-03-2007, 05:20 AM   #1
vincesf's Avatar
987 Exhaust Tip Question
Does the 987 Exhaust Tips easily change out? I noticed a nut holding a clamp that looks easy enough, to remove, and then I would imagine it slips off, but is that it?
vincesf
vincesf is offline   Reply With Quote
Old 12-03-2007, 06:20 AM   #2
bmussatti
Posts: n/a
Vince, you are correct. I watched the dealership do mine for a warranty repair. The chrome tip had a very slight pit, and I had them replace within the first few weeks of ownership. Looked very easy.
Old 12-03-2007, 06:57 AM   #3
If it refuses to give; jiggle it!
When I replaced mine; it was very snug. I used WD-40 to loosen it up. Once out, I cleaned it and the new one slipped right in.
Have Fun!
JustJack is offline   Reply With Quote
Old 12-03-2007, 07:09 AM   #4
Loosen the bolt and pull it off. Initially I had to kinda work it side to side to get it off, but added WD40 when I put it back on and that helped.
05 987 S SOLD
Arctic Silver
Bose/Xenon
05 Touareg V8
Black
drburton is offline   Reply With Quote
Old 12-03-2007, 07:19 AM   #5
Yup.
Loosen the nut. Slide it off.
Easy greasy.
Best,
- Mark
Houston C4S is offline   Reply With Quote
Old 12-03-2007, 07:30 AM   #6
I am after a nice 987S replica for my 2.7.
Can anyone recomend one?
necroscope is offline   Reply With Quote
Old 12-03-2007, 07:45 AM   #7
bmussatti
Posts: n/a
Necroscope, there are some nice choices here:
http://e-partssales.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=P&Category_Code=986exhaust
But, the exhaust tip change process is not so easy with the 986. A lot depends on the year of your car.
Old 12-03-2007, 12:57 PM   #8
vincesf's Avatar
Thanks all. I am thinking of installing the optional Cayman Chrome Exhaust Tips, which must be interchangeable as Porsche lists it in their Tequipment Accessories Booklet for Boxster.
vincesf
Old 12-03-2007, 01:43 PM   #9
bmussatti
Posts: n/a
Vince, here is one place to buy that tip:
http://e-partssales.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=P&Product_Code=98711198100&Category_Code=987ext
Old 12-03-2007, 01:56 PM   #10
vincesf's Avatar
Originally Posted by bmussatti
Thank you!
vincesf
