Old 10-07-2007, 08:28 PM   #1
Are all the hardtop for boxster same07-04?
Hi looking to buy used hartop for my 03. Do i need specail clamps,bolts? or does it just click into place the same as the softtop connections? thxs
eomak is offline   Reply With Quote
Old 10-08-2007, 01:56 AM   #2
At the front they are the same. At the rear you need a special fitting kit installed. They are not expensive, over here you can get them for 40 GBP, I guess they will be $75-100 from your local Porsche dealer.
noone986s is offline   Reply With Quote
Old 10-08-2007, 07:43 AM   #3
There Is No Substitute.
rick3000's Avatar
You need to install spinlocks in the back, on each side. Sunset Imports is the cheapest I found at about $65. You need the two bolts and right and left spinlocks. If you call them they should now what you're talking about.
Old 10-08-2007, 12:24 PM   #4
KevinH1990's Avatar
Here are some instructions for installing the spin locks:
http://www.renntech.org/forums/index.php?showtopic=10440
I think you will have to register on RennTech to view the topic.
Good luck finding and installing your hard top.
Old 10-08-2007, 01:23 PM   #5
hello, thanks again for replies.
Old 10-08-2007, 01:52 PM   #6
KevinH1990's Avatar
I had the black plastic caps on mine, but I had to install spin locks.
Lock at the sketches in this technical bulletin:
http://www.renntech.org/forums/index.php?act=attach&type=post&id=5526
Basically, if you see a round empty hole when you remove the black plastic caps, you don't have the spin locks.
Old 10-08-2007, 04:25 PM   #7
The hardtops will not fit all years. The tops changed with the model changes. 986 needs that series top, different from a 987.
http://i122.photobucket.com/albums/o...986/986sig.jpg
2002 Boxster S
SC986 is offline   Reply With Quote
Old 10-08-2007, 05:56 PM   #8
If anyone with a hard top no longer wants their black plastic caps, I would like them.
PM me if you've got them lying around in your tool box gathering dust!
