Old 10-01-2007, 12:35 AM   #1
Rear Wheel Bearing, HELP
Hi,
I need to change my right rear wheel bearing on my 2002 S, and its a bummer, but I guess it happens. he dealer asks for 850 which I have read here is way expensive. I've seen them for 250, since the part is 30 ish dollars I dont see all that work done to it. They even told me it would take 3 days in the shop to do..
Well, my question now, I need to go to Vegas this week with my girl. Can I drive on it? I hear a swosh swosh sound as the wheel turns around, but what can happen? Worst case I need to get a new wheel bearing? Well I am already doing so or what could happen IF worst came out?
cristopher
*youth is wasted on the young*
Photos of my Boxster S
Painted center console, artic silver
, De Snorkle, 18" Carrera lightweight - 285-30-18 - Fabspeed Exhaust
http://www.cristopherbenitah.com/boxster.jpg
cbenitah is offline   Reply With Quote
Old 10-01-2007, 01:36 AM   #2
boxsterz
Guest
Posts: n/a
Lose control of the car. The wobble might be enough for severe changes in toe or camber.
Old 10-01-2007, 06:12 AM   #3
I recommend buying the part from Sunset and finding another mechanic who will work for you by the hour, not with a book rated job quote. Mine only charges me for the actual time he spends on the job, which is about $80 an hour.
It's about a two hour job to swap a wheel bearing. It does require a bearing puller/compression tool though, which isn't cheap to own.
Old 10-01-2007, 12:45 PM   #4
If you continue to drive it (i.e.-Vegas trip)
Best case= further destroy failing bearing and potentially destroy connected equipment costing you a lot more $$$
Worst case (as stated already)= lose control of the car, more $$$, bodily injury
You should rent a 911 or a Ferrari at one of those exotic rental places in Vegas!
Jeff Wilson
1989 911 Cabriolet
Grand Prix White/Black
33k
Stock except:
Turbo 7x9 Fuchs
SOLD!
2002 986S
Seal Gray/Black
Painted Center Console
18" Turbo Twists with rear spacers
Tequipment aluminum shift knob
Colored center caps
De-ambered tail lights/side markers
Stock except:
B&B catback exhaust
http://i29.tinypic.com/i6crck.jpg
jwilson95 is offline   Reply With Quote
Old 10-01-2007, 03:21 PM   #5
I wouldn't take a chance on an extended outing like that. If it does fail, how impressed is your girl going to be sitting on the side of the freeway?
Also, I waited too long to replace a rear wheel bearing on my 928 and ended up having to replace the hub. Not sure if it is the same setup as on a Boxster but why chance it?
2000 Black Boxster S
EVO Intake & GIAC Tuning
Headers & Porsche Sport Exhaust System
ROW M030 Suspension
Front & Rear Strut Braces
B&M Short Shift & EVO Billet Linkage
steve00s is offline   Reply With Quote
Old 10-01-2007, 10:19 PM   #6
Send a message via AIM to ultimate1 Send a message via Yahoo to ultimate1
I had this done on my 2000 a few months back. The cost would have been about $450 or so with labor. My warranty covered it so my deductiable was only $100.
You can drive it but you run the risk of damaging your wheel hub which would easily make this a $1100 repair or so. My advise is to get that quote in writing and contact PCNA as the quote given to you is outright excessive and the job takes a few hours not a few days.
I read the horror stories and I ******************** and moan sometimes when I have to fork over the cash to fix my car but I lucked out with the dealer and service guy that I deal with. They are not perfect and sometimes I have to wait for them to get my car fixed but never a 3 day wait and I occasionally get a Cayenne to drive around in when I need to drop off the car for repairs.
ultimate1 is offline   Reply With Quote
Old 10-02-2007, 09:48 AM   #7
I guess preventative maintenance (greasing) wouldn't be a bad idea when you change your tires.
2003 S
Arctic silver
Alive to drive
boxstershorts is offline   Reply With Quote
Old 10-02-2007, 02:13 PM   #8
Bearings are NOT servicable. They are sealed for life (whatever that means). Grease fittings are virtually non-existant on new cars now-a-days.
Gary S.:dance:
2000 non-S Guards RED
Mostly stock-so far...
rear speakers
3 spoke
K+N
Red bumperettes
Speedster humps
Planning:
some stinkin' cup holders
rebeltown is offline   Reply With Quote
Old 10-02-2007, 05:47 PM   #9
I got it from pelicanparts.com for 35 and somebody installed it for 150, they should not charge you that much!
juan986 is offline   Reply With Quote
Old 10-02-2007, 07:48 PM   #10
Then I guessed wrong. Can't wait to receive my new Bentley manual.
2003 S
Arctic silver
Alive to drive
