Old 09-07-2007, 04:48 PM   #1
Need Detail Advice
A friend is restoring a '69 covertible Z28. He got a great deal on used aluminum cleaner, valve cover, pcv valve.
It has a milky look and some water type looking spots. I tried two of the old standbuys: Master Formula polish and sealer, Adams Metal polish 1 and 2.
Nothing! They look like I never touched them. I know Aluminum won't shine like chrome but these two have always done well for me.
Any thoughts? My first time working with Aluminum instead of chrome.
http://i122.photobucket.com/albums/o...986/986sig.jpg
2002 Boxster S
SC986 is offline   Reply With Quote
Old 09-07-2007, 04:59 PM   #2
boggtown
Guest
Posts: n/a
If you want any shine your gonna need a buffing set. Google that kind of stuff and buy a kit with dremel/power drill attachments, different heads, and different buffing compounds.
Old 09-07-2007, 05:05 PM   #3
Pat
A Porter Cable random orbital buffer would help, but isn't necessary. You may want to try P21S metal polish. Both can be had from DetailersParadise.com
You may also want to tell DP what you're doing and they could give you some more advice.
"Of all the extreme sports I've ever participated in- windsurfing, kite boarding, wake boarding, tow-in surfing and snowboarding- skiing, for me, made everything else easy."
-Chuck Patterson
Pat is offline   Reply With Quote
Old 09-07-2007, 05:17 PM   #4
boggtown
Guest
Posts: n/a
A 2 second google search.
http://www.caswellplating.com/buffs/alpolkit.htm
Old 09-07-2007, 05:42 PM   #5
SC,
Has the aluminum been anodized? If so, you'll need to take it off with Easy-Off oven cleaner, the real stuff, not that environmentally friendly crap. Once you've determined that it's not anodized or you've removed it, you can get to work.
First, you'll need to wet sand the surfaces to remove the water spot damage and scratches, and to smooth the surface. I can't see what you're working with as far as a starting point goes, so I can only guess at what your surfaces look like. Try starting with an 800 grit, using plenty of water to keep the surface and paper wet at all times. If the 800 isn't stout enough to take the damage out, you'll need to drop down to an appropriate grade. If the 800 works for you, sand all the surfaces down to an even, dull finish. Then wet sand with 1000, 1200, 1500 and 2000 to remove the sanding scratches. Once you're satisfied with the surface prep (all of the damage is removed and you're left with a nice, even, dull surface with only the 2000 grit scratches visible, you can start polishing (you can skip the 1500 and 2000, but you'll just have to do more polishing).
You don't have to get too fancy with polishing equipment. If you don't have a die grinder or buffing wheel and the proper buffs, you can try a 4" wool pad on your electric drill. Instead of working your way through several stages of rouges, try a one step polish like Magic Mix. You might even try Mother's Mag and Aluminum Polish. I've had good luck with it. When you're done and satisfied with your results, you can seal the whole project with Zoop Seal, which will keep it from tarnishing for a year.
By the way, there's no such thing as a '69 Z-28 Convertible. The Z-28 was only produced as a coupe.
http://i84.photobucket.com/albums/k2...izzlysmall.jpg
'97 986
Cheating Death on 19" Wheels
...no catastrophic engine failure ...yet
Grizzly is offline   Reply With Quote
Old 09-07-2007, 05:50 PM   #6
Send a message via AIM to djomlas
http://www.poleringsguide.se/english/
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
Old 09-07-2007, 07:37 PM   #7
Originally Posted by djomlas
Do you know if the polishes he references can be sourced in North America?
wanna986 is offline   Reply With Quote
Old 09-07-2007, 07:42 PM   #8
im not sure, BUT, it was found trough LS1tech.com, mainly a camaro/vette kinda site, so it ties in w the thread hehe
Old 09-08-2007, 09:24 AM   #9
Thanks for the info guys. You're right Grizzly, it is actually a SS.
2002 Boxster S
