Old 08-20-2007, 09:19 AM   #1
blkboxster
Guest
Posts: n/a
Driving in rain desnorkled
is it ok?
thanks
Old 08-20-2007, 09:27 AM   #2
Send a message via AIM to blinkwatt
Dude it's cool,think about it. You've seen what the snorkel connected to correct? Rain would have to be shooting from a 90 degree angle to get in the intake system. Even then it has a uphill climb and has to get past the air filter......highly unlikely.
*No aftermarket intake kit has a snorkel and air is brought in from almost the same location as a desnorkeled system. I hope that makes sense.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 08-20-2007, 09:53 AM   #3
Your car, and all cars for that matter, ingests a certain amount of water when you drive in the rain. Even in a deluge, you won't suck in enough to harm your engine. It's not until you drive through water deep enough to submerge the intake that you need to worry.
Wret is offline   Reply With Quote
Old 08-20-2007, 11:37 AM   #4
I don't know about the technical aspects, but I have been driving in rain for 3 years now desnorkeled and have not had any problems. Hope this helps!
However, if you desnorkel, you must not drive your car through an automated car wash (which you probably wouldn't do anyway but is worth mentioning) and you should not shoot your hose into the intake when washing the car in the future.
And one more thing... don't flick your cigarette butt out the driver's side window whilst driving down the road or it could be sucked into the intake and cause a fire.
Old 08-20-2007, 12:18 PM   #5
the airfilter should prevent hydrolock in most situations.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 08-20-2007, 12:40 PM   #6
What's hydrolock?
Old 08-20-2007, 12:43 PM   #7
By the looks of it to me. It would be easier for moisture to get into the intake w/the snorkle than w/o. Not saying it is something that can happen really either way in my opinion.
"You finally got that Nazi-go-cart you always wanted." -Peer
http://i40.tinypic.com/ei6sns.jpg
pompous is offline   Reply With Quote
Old 08-20-2007, 12:52 PM   #8
I was thinking that as well. The snorkel tube could act as a tub to hold water.
Oh well,if you really want to make sure you don't get any water in there just buy the update louvre that has the bottom two fins(?) connected not allowing anything in through the bottom.
Old 08-20-2007, 01:22 PM   #9
In automotive terminology, a hydrolock (short for hydraulic lock) is the immobilization of an engine's pistons by a liquid (usually water, hence the prefix "hydro-"). Hydrolocking occurs when liquid fills a cylinder on the intake stroke and, due to the incompressibility of a liquid, makes the compression stroke impossible. This, in turn, prevents the entire engine from turning, and can cause significant engine damage if one attempts to forcibly turn over or start the engine. Typically, connecting rods will be bent, making the engine uneconomical to repair.
It is relatively common when driving through floods, either where the water is above the level of the air intake or the vehicle's speed is excessive, creating a tall bow wave.
Hydrolocking is often a concern when consumers modify their engines with aftermarket intake systems (e.g. Cold air intake). A cold air intake typically locates the filter near the bottom of the engine compartment to gain access to colder air, which can also increase its chances of ingesting water should it be submerged.
Another reason for it to occur is in the event of the head gasket cracking or "blowing", which causes the radiator coolant to mix inside the combustion chamber.
( from wikipedia )
Nick
http://i146.photobucket.com/albums/r...s/DSC03717.jpg
1999 986 ( Black )
1998 MB C280 ( Black )
1999 BMW K1200RS ( Yellow )
2005 Audi A4 ( Red )
NickCats is offline   Reply With Quote
Old 08-21-2007, 06:57 AM   #10
Hydro lock is when enough uncompressible liquid, usually water, enters the cylinders to prevent the pistons from completing the compression stroke. Unfortunately, some other parts often continue their cycles in spite of the blocked pistons.
Old 08-21-2007, 08:56 AM   #11
I was driving from Louisville to Knoxville on Sunday when I encountered a large downpour. All was fine.
http://img412.imageshack.us/img412/9591/65zxg8pcz4.jpg
2002 Boxster S
Guards Red/Black
Hacks: De-Snorkeled, Clutch Swich, Debadged, Red Seatbelts, Painted Bumperettes,
986S Badge, EVO Intake, SuperSprint Exhaust, Fabspeed Cat Bypass
My Car: http://s220.photobucket.com/albums/dd74/zackwatt/
zackwatt is offline   Reply With Quote
Old 08-21-2007, 10:49 AM   #12
Send a message via AIM to djomlas
i drive in rain and snow with EVO intake...all it is is a cone on a tube, and K&N to be exact...its fine.
we had some messed up rain these past few days and its all good...
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
Old 08-21-2007, 12:08 PM   #13
Originally Posted by blinkwatt
What's hydrolock?
Nothing good. Liquids are incompressible. If you suck water all the way into the cylinder, your pistons will try (and fail) to compress the water.
Expensive things will bend and break.
indydave is offline   Reply With Quote
Old 08-21-2007, 12:51 PM   #14
I've been skeptical of doing this "mod" but, yesterday I decided to take off my side vent and check it out. I had just got home and driven through the rain. Took off my side vent to discover that it was dry inside anyway. Just looking at that "snorkel" doesn't appear it does much of anything. A tube with a bowl on the end of it.
So, I desnorkeled since it's completely reversible anyway. Love the sound and if I were to get an EVO intake, the snorkel wouldn't be present anyway. I think it was put there as a safety precaution for Porsche so, they they didn't have to replace an engine if it were potentially damaged by their design.
Don't spray the garden hose in there when washing it, I don't do that anyway.
yellowboxster01 is offline   Reply With Quote
Old 08-21-2007, 03:55 PM   #15
husker boxster's Avatar
Wow! Are the animals pairing up? How long is a cubit?
1989 928 S4 5 spd - black
