Old 08-19-2007, 09:24 PM   #1
CV Joint Boot Replacement
Does anyone have a good link to a tech guide for removal of the CV joints to replace the boots? I have two split I need to change ASAP and getting my hands on a Bentley manual is seemingly impossible with there being a shortage from the publisher for whatever reason.
VTCMart is offline   Reply With Quote
Old 08-20-2007, 12:34 AM   #2
Just for you.....
http://986forum.com/forums/showthread.php?t=12775
(and anyone else whose boots have split)
http://i19.photobucket.com/albums/b1...dingAvatar.jpg
Sold September 4th, 2007.
Rodger is offline   Reply With Quote
Old 08-20-2007, 05:30 AM   #3
Originally Posted by Rodger
Just for you.....
That works for an inner boot but what about an outer? I have a broken outer and also havent been able to find a Bentleys, do you just unbolt the inner and then remove the axle nut for the outer? It might actually be easier as then you shouldnt have to touch the exhaust, any suggestions??
Thom
'81 911 SC ROW = The Money Pit
'02 Boxster S = Daily Driver
thomschoon is offline   Reply With Quote
Old 08-20-2007, 05:42 AM   #4
Here's the procedure for doing them all.
http://986forum.com/forums/showthread.php?t=4961&highlight=boot+replacement
Have fun!
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
Old 08-20-2007, 09:13 AM   #5
Come to think of it, that's the procedure I used when I did mine. I did mix it up a bit, though, because I had major difficulties getting the outer joint out of the hub. I'm 99% certain you could still do an outer the same way, you'd just have to remove the inner boot first (replace them all while you're at it).
Old 08-20-2007, 04:51 PM   #6
Thanks, that's a good step by step. Also, could someone post the torque specs referred to? Thanks.
Old 08-21-2007, 06:36 AM   #7
I found one of my outer boots split about 3 weeks ago, 1 week before my vacation (road trip). I installed a split boot without removing the axle. It's a little early for a longevity evaluation but after several hundred miles it still looks good.
Wret is offline   Reply With Quote
