Old 04-28-2007, 09:27 AM   #1
fab
fab's Avatar
center concole removal -HELP
I've started to remove my center console and now I'm stuck. I've loosen from the front all the way to the ash tray. This is where I'm stuck. From the key hole on it's tight. I don't see any screws. Help...
00 Boxster Tip Blk/Blk
100% de-ambered
painted center console
painted bumperettes
autoband paint protection
wheel caps & colored crests
door sills
Valentine One
fab is offline   Reply With Quote
Old 04-28-2007, 09:57 AM   #2
Use this:
http://www.bmracing.com/media/products/pdf/67.pdf
You probably haven't taken the screws out from under the box. Take the rubber bottom mat out and you'll see them.
I bleed green
Old 04-28-2007, 12:06 PM   #3
fab
fab's Avatar
Chils-
the instuctions helped
thanks
100% de-ambered
painted bumperettes
door sills
Valentine One
