Old 04-27-2007, 09:00 AM   #1
Convertible top motor
Can anyone post a picture of where the convertible top motor is located. My top is starting to go up slowly up and down I suspect that it is only a matter of time before I am stuck witht the top stuck open.
clb0099 is offline   Reply With Quote
Old 04-27-2007, 09:18 AM   #2
I don't have a picture, but the motor is located just ahead of your third brake light (closer to the front of the car vs. behind the lamp).
It has two cables that come out of it headed around the side of the engine compartment to the top transmission(s).
It is basically a screw-type mechanism that twists a wire inside the cables eminating from it that power the transmission on each side to move the clamshell and raise and lower the top.
Hope this helps!
Old 04-27-2007, 11:08 AM   #3
easy fix? I see the motors are not too badly priced ... Does anyone have instructions on replacing
Old 04-27-2007, 11:18 AM   #4
Not hard to replace, but one must be very careful when putting in the transmission cables because they must be timed perfectly or the clamshell and top will not rise or retract at the same time... causing top frame and clamshell damage
It would be very prudent for you to purchase a Bentley repair manual for the boxster, which can be secured from Amazon.com for this and future repairs.
