Old 05-27-2004, 12:09 PM   #1
Removing headlight triangles
Hello,
This might be a stupid question, but can someone tell me how to easily remove my amber triangles near the headlights? I want to install some clear ones.
Thanks,
David
Davey D is offline   Reply With Quote
Old 05-27-2004, 01:43 PM   #2
They pop out, by applying pressure from the back of the triangle. It is "usually" a pressure fit.
I found a little lubricant will help [WD-40].
The upper corner has a little lip which you will need to be careful with during the removal process.
It is basically slide and push; CAVEAT - be very careful with the tab edge. If worst comes to worst, you can super glue the little tab back on, but I have used them without the slide tab.
Scott
mrmickeymouse is offline   Reply With Quote
Old 05-27-2004, 01:51 PM   #3
Thanks a lot Scott. I'll give it a try.
Dave
Old 05-28-2004, 11:57 AM   #4
Dave, I just finished installing Litronics last night and I had to put on the clear triangles. I think the only way to do it is to pop the headlights out first and on the underside of the light assembly, you'll see the clips of the triangles. -- Dave
acf53 is offline   Reply With Quote
Old 06-03-2004, 06:45 AM   #5
acamachobadajoz's Avatar
litronic
Iīm thinking to change my 98`head ligths, for a clear head lights (non litronic). The total price its near 800-900€.
Whats the price for the litronic kit??? its only the kit for the Lights, or need to install another things.
Thanks in advanced.
acamachobadajoz is offline   Reply With Quote
Old 06-04-2004, 08:10 AM   #6
I bought the Litronics kit for 1099 us dollars. It's not plug n play, you need to do wiring - splicing and soldering. It takes about 3 hours. For just the clear lights, I think it's plug n play.
Old 06-04-2004, 08:18 AM   #7
hi
Where did you buy the kit?
Thanksss!!!
Old 06-04-2004, 08:35 AM   #8
I bought it from Suncoast Motorsport in Florida -suncoastporsche.com. They list for 1195 but I kinda bargained a little bit since I did find it somewhere else for 1099. They are great to deal with.
Old 06-08-2004, 06:32 AM   #9
litronics
But i had read, that if you install a litronic kit, you need to have a wasersh kit too. If you donīt have a wasersh kit, you willnot pass the inspections.
Its this real??
If itīs real......with the litronic kit, comes the wasersh kit???
thanks in advanced.
Old 06-09-2004, 01:56 PM   #10
not sure what a wasersh kit is. Can you please explain.
Old 06-10-2004, 03:33 AM   #11
sorry for my bad english..
Washers (to clean ligths with water)
Old 06-10-2004, 08:33 AM   #12
I don't believe you have to have the headlight washers to pass inspection. The orginal halogen set didn't have them either and it's always been an option whether to have the washer or not in either the Litronics or the Halogens.
Old 06-10-2004, 09:06 AM   #13
In some countries you need headlight washers if you have litronics in order to pass their vehicle inspection, but this is not true in the US. There is a headlight washer retrofit kit.
