Old 04-01-2007, 12:53 PM   #1
Did something really stupid-help!
I put windshield washer fluid in the coolant overflow reservoir-then drove the car. Once I realized what I had done, I siphoned off the amount I added from the reservoir. Seems to run okay-any serious damage done or to be expected? Thanks in advance.
docdyh is offline   Reply With Quote
Old 04-01-2007, 01:08 PM   #2
If this is not an April fools joke, I would guess you really need to flush out the entire coolant system before driving it again, period. Window washing fluid is a detergent and will likely degrade the effectiveness of the lubricants in the coolant....
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
Old 04-01-2007, 01:20 PM   #3
All those blue caps look the same.
Reminds me of the blonde joke about the 710 cap.
You are not the first, but most guys say their girlfriend did it.
So, how many gallons of windshield washer fluid did you put in the coolant tank. More like a cup or two I would guess.
Tool Pants is offline   Reply With Quote
Old 04-01-2007, 01:46 PM   #4
Hi,
The only damage you've done is dilute your coolant. Most pre-mixed Windshield Washer fluid is made of water, ethanol, or isopropanol, or ethylenglycol (usually labled Winter Mix).
Basically, you can just leave it in and you'll be OK. If obsessing over it, you can idle the car with the Bleeder Valve open and the alcohol solvent (ethanol, isopropanol) will just flash off, leaving you with a slightly diluted Coolant mix.
Next time you need a top-up, start by adding a Tsp or 2 of undiluted Coolant and you'll bring it back into balance.
While I wouldn't make a practice of doing this, the occasional inadvertent top-up with Windshield fluid won't harm it at all...
Happy Motoring!... Jim'99
Old 04-01-2007, 02:39 PM   #5
No joke...thanks Jim...makes sense.. only a cup went in...
Old 04-01-2007, 02:46 PM   #6
bmussatti
Guest
Posts: n/a
In the 987 the washer fluid is in the front trunk and the coolant is in the rear trunk. Where is the washer fluid on the 986?
Old 04-01-2007, 03:20 PM   #7
front compartment
Old 04-01-2007, 03:21 PM   #8
fab
fab's Avatar
ditto for 986...
00 Boxster Tip Blk/Blk
100% de-ambered
painted center console
painted bumperettes
autoband paint protection
wheel caps & colored crests
door sills
Valentine One
fab is offline   Reply With Quote
Old 04-01-2007, 04:54 PM   #9
Well that's good news! Sorry I jumped to that conclusion, I was certain the addition of the washer fluid would be detrimental, but I'm glad it's not.
kabel
