10-31-2015, 05:19 PM
I am my own mechanic....
May I recommend a product?
Absolutely fantastic.
'08 VW Touareg T-3 wife's car
11-01-2015, 03:21 AM
2003 Base 5-speed
Does it work on.......
very heavily coated, old brake dust? I have tried Maquiars all wheel cleaner, Car-Pro Iron-X and P21S gel. All to a good job of removing light or new brake dust. My rims seem to have old dust "baked" into them. I have tried adding light mild abrasive scrubbing as well. Gets them to about 85% of the result I want.
11-01-2015, 04:04 AM
Try SONAX.
Couple years ago I seriously thought the wheels would need resurfacing, powder coating. They looked that bad. Scrubbing them was little help.
Sprayed on SONAX, available Amazon etc...
Spray it on, watch it change color from green to red, 3-5 minutes, spray off w/high pressure water at coin operated car wash.
They came out looking like new, and I have spoke type wheels.
11-01-2015, 04:29 AM
Been using sonax for quite a while and it is a great product. I try to take the wheels off about every 15,00 miles ( which comes pretty quick for me ) and inspect the brakes, tires, etc and give the wheels a good cleaning with sonax and then a couple of good applications of wax.
11-01-2015, 04:58 AM
I swear by P21S...
11-01-2015, 05:06 AM
2003 Base 5-speed
Well, what's one more product to try......
...in the search for perfection?!?
Here's what mine look like:
11-01-2015, 06:05 AM
What I'm talking about.
After repeated scrubbing w/various products still that had that type niggling trace, which is why I thought it needed resurfacing or repainting.
Sonax removed it.
Problem solved.
11-01-2015, 07:06 AM
2003 Base 5-speed
Sonax removed it.
Problem solved.
Ok, thanks! I'll gave Sonax a try. BTW, I just went out and gave the trouble spots a mild wipe with Maquiars compound. Seems to work pretty well. When I have time I may go back more thorougly.
11-01-2015, 07:25 AM
Griot's Garage heavy duty wheel cleaner is the bomb!. It also smells good
Tried P21 and sonax and prefer Griot's Garage
11-01-2015, 07:35 AM
Just wax your wheels and very little dust will adhere and what does will come off with water.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
11-01-2015, 07:41 AM
2003 Base 5-speed
Yep, but no sense waxing them until they are cleaned up to my satisfaction. Some wouldn't care, and my car is 12 years old and hardly ready for a concours - but clean, sharp wheels make any vehicle, no?
11-01-2015, 08:47 AM
The slicker a surface is the less sticks to it. I use old clay bar for tough wheel stains. Then wax.
11-01-2015, 09:08 AM
2003 Base 5-speed
Thanks for all the suggestions! And Timco, I didn't intend to hijack the thread. BTW, your wheels and calipers look awesome. And your Anniversary edition in GT Silver metallic with cocoa interior is one of my favorite color combos of all 986's. Just a beautiful Box!
11-01-2015, 09:18 AM
I'll have to try that, I've used Eagle One wheel products before with great results.
1999 Boxster base w/sport package Ocean Blue Metallic/Savanna Beige
11-01-2015, 09:42 AM
I used the Hot Wheels wheel cleaner for about a year and it peeled the clear coat off my red Boxster S calipers...
Never again.
One thing I did do was take off the wheels and clean off all the brake dust from the rim and back of the spokes with a power washer and then applied 3 or 4 coats of Armor All Wheel Protectant. It did make the brake dust easier to remove....
2002 Boxster S, Arctic Silver, 18" Turbo Wheels, 6-speed
11-01-2015, 09:46 AM
It's a topic more than a thread. I have some products to try myself!
11-01-2015, 09:55 AM
I've had great results from Sonax wheel cleaner plus, especially when applied to dry wheels. I only use it in really bad wheels, though, because of how expensive it is. To maintain already clean wheels, I like to keep a layer of sealant on them and wash thoroughly and frequently with car wash shampoo. I use an EZ-detail style wheel brush to clean inside the barrels and behind the spokes. I use a 1" round pastry brush to clean the lug nut holes. I'm experimenting with using spray-on quick wax after the routine cleaning, to keep a good sealant going on them.
11-01-2015, 11:03 AM
after you get them clean, apply rejex. it is a polymer coating that makes it easy to keep clean
Wax does not last very long, especially if you track the car and the wheels get really hot
11-01-2015, 01:36 PM
If you can get a great product over the counter I consider that a plus over a boutique brand that requires you pay shipping or requires you place a larger order to get free shipping.
11-01-2015, 02:59 PM
Agreed. Looks good.
HTML code is Off
