Old 05-19-2007, 11:41 AM   #2
Chills
Send a message via Yahoo to Chills
I installed an in-dash GPS system. I put the antenna right where you want to. If your cable is long enough you can route it under the passenger dash, then have it come out by the door, up the side, around the a-frame, then down into the crack between the windshield and the dash.
I bleed green
It's not about the summit, it's about the climb.
http://i133.photobucket.com/albums/q46/chills1138/2.jpg
Chills is offline   Reply With Quote
