Old 02-07-2007, 07:45 PM   #3
ray986s
bearing noise
An easy way to check if it is the bearing is find an empty quiet parking lot, turn off the radio and roll down the window cruising at about 20 to 25 mph swerve side to side if you hear that moaning noise get louder and softer as you swerve in opposite directions it is you bearing. The side where you swerve and hear the noise is most likely the bad side. I had a bearing go bad at about 35,000 miles, part was cheap less than 50 bucks each, but very labor intensive. Must remove the hub and have the bearing pressed out and new one pressed in. You will also need the tie rod tool to remove a couple of tie rods...
986s sport design pkg, aerokit 1, litronics,deviating seat stitching, guards red seat belts, cf ebrake/shift knob,ssk, sport seats, hard top, full alpine system with 8" sub, mb quart speakers, Champion rg5, Eibach springs, sport exhaust, rear stess bars, custom ecu program, desnorkle intake, euro bumper, rear diffuser
ray986s is offline   Reply With Quote
