Old 01-17-2007, 04:51 AM   #10
z12358
Originally Posted by MNBoxster
Hi,
True, but if you use the 9-volt jumper I described, you can use the Lock/Unlock Tip Switch to open them. These are available from several Auto Parts Retailers and usually go by the name Memory Savers. Usually under $12. See: http://www.drivewerks.com/catalog/shopcart/TOOL/POR_TOOL_CAT439_pg3.htm
Hope this helps...
Happy Motoring!... Jim'99
Jim, I assume that this 9 V memory saver can not be used to actually jump start the car, so one would need to have jumper cables on board, anyway. Looks like Boxtaboy's (lighter-to-lighter) solution solves both opening of the trunk and jump starting. Or perhaps I'm missing something.
Boxtaboy, how's that product called -- for an online search?
I don't have the manual handy to check on the proper jump start procedure for the Box. How is it different from the standard jump start?
Thx.
Z.
'06 Boxster S, 6sp, triple-black
http://i153.photobucket.com/albums/s...05_IMGcrop.jpg
z12358 is offline   Reply With Quote
