Old 01-01-2007, 09:36 AM   #3
bmussatti
Guest
Posts: n/a
Originally Posted by kls
"Hi Kls:
1) What are your tire pressures?
2) What are your tread depths as measured in mm or 32's?
3) You should always have both hands on the wheel , as this is the preferred driving position."
I'm running 29 lbs in front and 36 rear. The rear tires, at their worst, have 4/32 of tread and the front 6/32.
Kls, you need new rear tires...soon. When new, our tires are about 10/32's. Tires are considered "worn out" at about the 3/32nd mark.
