Old 01-08-2025, 10:44 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by kdh View Post
Will the muffler drop down if i ONLY remove the two allen key bolts from each of the silver cylinders?
Since I'm doing Boxster stuff today...
If everything else is clear of the muffler, yes. The allen bolts are threaded on the inside and screw onto studs on the muffler:
I'm still wondering why it is impossible to remove those two nuts. I am of fairly standard proportions, losing some flexibility now over 60 years old, 6' tall, 190lbs, and wear size (L) gloves. On my 2004 S I can reach the nuts without trouble and don't need to remove anything or jack the car up to do it.
I first break the nuts free with a standard 3/8 ratchet and 13mm socket, then remove it with a shorter wrench.
I am exceptional in many ways, but have no skills as a mechanic other than being stubborn and persistent.
