Old 01-02-2025, 09:02 AM   #1
Wret
After replacing several front suspension components, I took may car to a nearby Mr Tire for an alignment. The guy said I had seized control arms in the rear and couldn't adjust but he got my front tow in spec. I had to cut out one rear toe control arm but everything else was still free. After all this I wanted get my alignment somewhere in the ballpark before driving 20 miles to my usual mechanic.
I had some down time waiting for parts and a lot of time off during the holidays so I put together some alignment tools based on some aluminum extrustions, a laser level, and 3D printed parts. I devised this method years ago when I was swapping alignment specs for autocrossing. Basically you mount the laser level on one wheel and a target grid on the other end to check front and rear against each other. I added a phone holder for camber. The "bubble level" apps you can get these days are really good.
This method allows you to see everly minute toe angle change as you adjust.
Wret is online now   Reply With Quote
