Old 08-11-2024, 10:08 AM   #3
A 986 S
A 986 S's Avatar
Sure, I'll share the file! My son Andy tells me that he made my nozzles with his resin printer because it produced far higher resolution part than his filament printer could make. He also said that the resin print would be more durable than one made with the PLA plastic that his filament printer uses. Keep that in mind when you go to the library... Do let us know if you're able to print nozzles that you can use.
The STL file can be found here; https://www.thingiverse.com/thing:6725822
Here's a screen shot of the 3d model;
And the instaled nozzles;
cheers - dj
2002 Boxster S Orient Red Metallic / Graphite Gray
https://rx19jones.wixsite.com/a-986-s
A 986 S is online now   Reply With Quote
