Old 03-06-2024, 10:15 PM   #1
MasterDesigner
Originally Posted by EmergencyMexican View Post
Hey everyone, thank you for your suggestions! The problem that was killing the battery was the voltage regulator on the alternator. I found this by hooking up my multimeter to the battery terminals when the car was running. It was reading something like 14.699 volts. I replaced the voltage regulator and the battery has not died since.
However now I have a new problem. The coolant temperature gauge light is flashing slowly, which makes sense because the engine compartment purge fan runs at 100% from the moment I turn the key, until a few minutes after the key is taken out. Also the CEL is still half lit. I bought an ebay engine compartment fan and swapped it out, but the same two issues appear.
the flashing light on the temp gauge indicates low coolant level
MasterDesigner is offline   Reply With Quote
