Old 04-26-2023, 12:05 PM   #11
blue62
Originally Posted by LoneWolfGal View Post
The more I research the problem, the more convinced I am that you're right about it being an issue with the EVAP system. Good call, blue62. After inspecting the hoses I think I'll begin with replacing the charcoal cannister, since it seems the most likely culprit. I'm not getting a CEL and it's my understanding that a too-full cannister doesn't throw a code. If replacing it doesn't solve the problem I'll look at the purge valves. In any case, I'm going to wait until my shop manual arrives before tearing into it.
You could do a search here on the forum for EVAP system issues.
One of the members here has excellent pictures of various systems on theses cars.
Once you know how things are laid out you can test things like hoses or cannisters by applying a vacuum and see if the vacuum will hold with something like a handy vac.
My reasoning for not going with the fuel pressure regulator vacuum line .... is that at starter cranking speed there is the least amount of vacuum being applied. I could be wrong but it doesn't make sense to me that a vacuum operated fuel pressure regulator would have any affect on fuel pressure with the least amount of vacuum applied.
Much more likely that the fuel pressure regulator comes into play when the greatest amount of vacuum is applied to it.
