Old 04-23-2023, 11:10 AM   #1
Luckyman01
RE Fuel pressure situation
I had the same problem, while there can be a number of reasons, in my case I eventually found it to be a bad vacuum hose from the intake to the fuel pressure sensor on the fuel rail.
Viewed from the back on engine compartment, it is on the fuel rail, left upper corner.
Hopefully this will help and you can avoid the throw parts at it path I went down.
David
Luckyman01 is offline   Reply With Quote
