Old 09-02-2022, 12:29 PM   #1
Goldenzrule
Originally Posted by 9864ever View Post
It's definitely not powering up. I'm assuming it's not because the fan isn't spinning. I might dig into the wiring next to see if it's cut anywhere.
I wish I could be more help. At least you can probably narrow the search down to the amp if it indeed is not powering up. I also don't know if the amp has a separate fuse or not. I would assume it has the same fuse as the head unit, but you never know. Would be nice if it was just a simple bad fuse issue. If fuse is ok, I'd try unplugging the amp and plugging back in just to make sure it has a good seated connection
Goldenzrule is offline   Reply With Quote
