Old 07-31-2022, 06:21 AM   #1
Boxstard
It is a purge valve that operates on PWM signal, so you will hear light tapping noise when it is running as the plunger goes up and down.
I do not think this valve is causing the coke bottle noise or gas filling issue, as it only controls vacuum/ flow to purge the charcoal canister. It is normally closed, and even if it gets stuck open, it should not cause your issues while the car is parked with engine off.
You need to replace the other valve up front near the filler neck.
By the way, that Bosch purge valve is a standard one used on many other makes and models, and you can just cut the PA tube and replace a valve using a short silicone vacuum hose to connect them back together. Personally I won’t spend that much money for a hose assembly.
