Old 03-26-2021, 07:15 AM   #10
ike84
The frunk will not open if the battery is disconnected.
Should be a pull cable behind the right front wheel well liner.
Do a search here on the forum should be info and pictures on cable location
You can access that cable from the circuit panel in the driver's footwell. Remove the panel cover and the front of the housing and the cable will be lying at the bottom.
Sent from my POCOPHONE F1 using Tapatalk
