Old 01-11-2021, 05:41 PM   #17
kbod
Glad to try and help just hope I have in some small way
Hoping the Cam position sensor is the issue
Keep us posted I always like to hear results.
Ok, I think I made some progress today, I removed the AOS and replaced the cam position sensor but when putting the car back together I realized the skinny coffee straw looking vacuum hoses are all missing and just disconnected and screwed up. As to why there is a spiderweb of skinny fragile hoses in a porsche is beyond me. But I didn't put the car back together as this seems like a lead into why my car is running like crap. do you know what part number it is for all those really skinny vacuum hoses along with a routing diagram or maybe just a complete upgrade as my car clearly did have some sort of air injection leak. I am hoping I could replace those little hoses and then put on my new AOS, check the timing and if it all works.. well.. im not gonna get excited yet. Also I am going to have to replace a couple of the big vacuum hoses as they were brittle and snapped when i removed them,
edit! I just ordered a new crankcase breather hose and 4mm silicone hoses with a bunch of 3/16 fittings, once they come In I will replace all of the skinny little vacuum hoses, then put the car back together and check timing. If even after that It still runs bad i will report back on deviations etc, Im just wondering, if it was an air leak why would the car put a p1341 instead of... maybe an air leak code!!! darn it porsche you are driving me insane
kbod is offline   Reply With Quote
