Old 01-01-2021, 01:42 AM   #1
kbod
Lets see what your cam deviation shows after you change out the cam sensor.
Then I will describe a way to use your Durametric to test your MAF sensor. Faulty MAF can cause lumpy idle.
But I will tell you how to test it after we see if the new Cam sensor cures the problem.
Sounds good, I will order a new camshaft position sensor right now, and I believe the bank 1 sensor is below the air oil separator so Ill use it as an opportunity to replace that since i experience smoky startups sometimes!
thanks for the help, ill report back once i do the swap!
kbod is offline   Reply With Quote
