Old 09-25-2020, 02:06 AM   #1
MAXF1net
Found some additional data about Yellow Speed Racing Dynamic Pro Sport Coilovers here https://www.ysreurope.com/yellow-speed-racing-dynamic-pro-sport-coilovers-porsche-boxter-986.html
Spring rates - F: 6 kg/mm (336 lb/in) R: 8 kg/mm (448 lb/in)
I also got the response from Donald Patterson
"Height is typically up to around 3" of drop at the lowest. Rebound and compression is adjusted simultaneously via 1 knob on each coilover. The camber plates on ours and most other brands typically offers around +/- 2.5 degrees. No camber adjustment in the rears as they are a solid mount w/ rubber bushings."
So no independently adjustable compression / rebound here. I think Bilstein B16 and KW v3 has that, as well as JRZ RS One.
What are your recommendation for coilovers + camber plates at least for front wheels? I want independently adjustable compression / rebound, ride height adjustment and camber adjustment at least for the front.
Total budget is max 4000 USD (including camber plates if not included in the coilover package)
Thank you!
MAXF1net is offline   Reply With Quote
