Old 09-22-2020, 06:54 PM   #1
tonythetiger
Will there be cake?
tonythetiger's Avatar
The top drive system on the the Boxster is elegantly simple. One small electric motor drives to cables (think old bicycle speedometer cables) that are connected to a gear set on each side (top transmissions).
Start with easy stuff...get some lithium grease and grease the tracks and pivot points. If no improvement. Look at transmissions as they have plastic gears and my have lost a tooth or two. Easy DYI. You can get used parts and save a few $$ if needed.
yes...grease. if you inspect the transmissions, drivers side has a microswitch in it, make sure you keep the timing right or your fixing the sync.
eBay is the place to get gears for a reasonable price, (40 bucks, so not reasonable) they seem OK but check the feedback. Some folks making them aren't doing a good job, judging from reviews.
I would skip getting used ones as the issue is old plastic getting brittle, so why buy old plastic?
