Thread: window symptoms
Old 09-19-2020, 09:34 AM   #10
tonythetiger
Will there be cake?
tonythetiger's Avatar
Originally Posted by hookoo3 View Post
I had a similar problem when the cable for my top was broken. There is a micro-switch in the convertible top transmission. If your cable broke without it being able to trip the micro-switch the windows won't drop. Once I got the cable installed and synchronized the windows worked normally.
Yes, as I discovered, the left transmission has a microswitch inside of it. If you are manual top, you have to keep the boomerang (lever from the transmission that the push arms attach to) in position to make the switch and get normal window operation, as well as turn off dash light telling you the top is ajar.
