Old 04-28-2020, 11:36 AM   #2
geekdaddy
THANK YOU -- that was helpful! I'll inspect and likely replace the input shaft seal.
I was wrong about the pilot bearing -- it's still in the flywheel.
I popped it out and it looks to be in good condition although I will put a fresh one on.
The transmission is very similar to the 01E transmission used in Audis and a few VWs. If you can't find much Boxster specific stuff there's more on the 01E if you are looking at seals or bearings in general.
stuff like this https://forums.quattroworld.com/s4s6/threads/28360.phtml
geekdaddy is offline   Reply With Quote
